TUTORIAL - Full Console Removal
Old Oct 17, 2012 | 05:17 PM
AKCallahan's Avatar
AKCallahan
Default TUTORIAL - Full Console Removal
Passenger side pocket is a good place to start. It has a slight lip where you can pop the first clip off. Open console to allow a flathead screwdriver to be used to pop the remaining clips.
As you see, there are a total of 7 clips, and where you'll need to unfasten each CAREFULLY.
Remove these two screws. This plastic tub looking piece will come out very easily.
Remove these two bolts.
This piece will need to be pulled off as well, and isn't being held in my anything anymore since the last two bolts had been removed.
With your head on the carpet, look up and see 2 of these...go ahead and remove both.
I again started on the passenger side, and began slowly popping off the bezel. Note...its easier to drop the entire bezel if you put the truck in 1st gear, and move the bezel out then put the truck back into park.
When you're done doing your do, carefully place each clip back into its place and secure the pieces of the console in the opposite fashion in which you took them off.
Old Oct 17, 2012 | 05:22 PM
willdikem66's Avatar
willdikem66
I support your open carry lol!
Im sorry when we were trying to help you with this i didnt even realize that you had the newer style. So all my "help" was worthless sorry again
Old Oct 17, 2012 | 05:31 PM
AKCallahan's Avatar
AKCallahan
That's where the glock goes when I'm in the truck, but then goes into the waistband once I'm up and about. We don't have OC here in Arkansas, thank goodness. That'd be a long day EVERYDAY at work.
I appreciate your help, it's no problem that it didn't help much. Still shows me at least that you're willing to make a decent attempt at helping rather than just looking at the thread and spouting off some BS. lol
Old Oct 17, 2012 | 05:45 PM
willdikem66
Lol ive been know to spout off some BS!
Still a great write up though, someone will get a good helping hand out of it.
