Gas pump shutdown way?
Old Oct 21, 2012 | 09:47 AM
jose1036's Avatar
jose1036
Default Gas pump shutdown way?
Hi everyone, I have a 2006 Ram with 5.7 Hemi. I trying to make the fuel pump to stop working in order to clean up the fuel injectors using a cleaner canister. There is no fuse nor relay to control the fuel pump, since it is controlled by the PCIM. Does anyone has a clue how to do this? Thanks.
Old Oct 21, 2012 | 01:56 PM
sabin420's Avatar
sabin420
I believe Dodge always puts a relay in called the Auto Shutdown Relay. It's under the hood next to the battery. And there should be a fuse, and their is a harness connection on top of the fuel tank if you can reach it.
