Swapping gears in 9.25?
Old Oct 30, 2012 | 09:04 PM
Plainbroke's Avatar
Plainbroke
What transmission and tire size are you running? Since this is a transplant please show some pictures ect. Big intrest in this subject.
Old Nov 2, 2012 | 12:26 AM
Chris_03_Hemi_4X4's Avatar
Chris_03_Hemi_4X4
Agreed I'd love to see some pics. I have been thinking about doing the swap for a while now.
Chris
Old Nov 2, 2012 | 08:58 AM
08HEMI1500's Avatar
08HEMI1500
You really invest in a 5 speed with 2 ODs like the autos have because there is no reason you should be running 1900 RPMs at 60-65. Especially with 3.55s
Old Nov 2, 2012 | 02:27 PM
willdikem66's Avatar
willdikem66
Yeah that seems a little high. When im doing 70 its right at or under 2k and i have a 4x4 with 3.92s
Old Nov 3, 2012 | 02:55 AM
Brandon Anderson's Avatar
Brandon Anderson
At those RPMs, it sounds more like the older 48RFE auto than the 5spd manual.
After '97, the highest gear option I've found is 3.21. I don't know if Chrysler changed the 9.25 12 bolt rear after '97 or not, but you can get as high as a 2.71 ratio labeled for pre-'97 rear ends. All else being equal, it appears ANY gear set sold for a 9.25 will work, regardless of year, but Chrysler never put a ratio higher than 3.21 in any of their trucks. I think it's a testament to the engineering of the 9.25 that it has held up to the torque output of that Cummins without breaking so far. Anyhow, you can get the gears here: http://www.drivetrain.com/parts_cata..._pinioins.html
