0420 code
Old Oct 26, 2012 | 05:21 PM
dougiedododge's Avatar
dougiedododge
Default 0420 code
I just had a fuel system cleaning done and valvoline syn3 was used.20 miles down the road CEL came on and was giving a 0420 code.Im wondering if the carbon being cleaned out is burning off and giving the code.Is the a possibility.It came on after the intake and throttle boddy cleaning and i had it turned off it went a couple days and came back on but im thinking because i had a full tankof gas and they put bottle of cleaner in the tank and im at a half tank now.is it still cleaning and burning the carbon and throwing the code.
Old Nov 3, 2012 | 06:43 PM
SC_Ram's Avatar
SC_Ram
Could be.I'd burn as much of that tank as I could w/out getting too close the bottom.I would then fill up again,reset the CEL and see if it comes back on.
Old Nov 4, 2012 | 07:51 PM
p38251's Avatar
p38251
How many miles? Its quite possiably the o2 sensor is bad.
Old Nov 4, 2012 | 11:07 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Could also be a crack in the manifold or broken header bolt allowing fresh air to get inside the exhaust stream
