T-stat leaking
Old Oct 27, 2012 | 06:37 PM
brad m's Avatar
brad m
Default T-stat leaking
I have replaced the t-stat about 8 months ago now its leaking again. Has anybody had problems with the housing. I'm going to buy another gasket or stat and thinking of replacing the housing. Is this a common problem.
It's a 2004 ram 1500 with the hemi.
Thanks for the help.
Old Oct 27, 2012 | 09:17 PM
HammerZ71's Avatar
HammerZ71
Nope, not too common. Put you some RTV on the gasket this time and you should be golden...
Old Oct 27, 2012 | 09:54 PM
brad m's Avatar
brad m
Thanks for the help. I will try rtv when i replace it.
Old Oct 28, 2012 | 07:28 AM
dirtydog's Avatar
dirtydog
Moderate User
ditto. I always use RTV sealant with paper gaskets. If there is ever an o-ring type gasket for those, a small bead on the outer edge helps as well. It'll help if the contact area the o-rings rests against isn't prefectly smooth/clean because oxidization of the aluminum is inevitable with coolant.
Old Oct 28, 2012 | 08:16 AM
vietti's Avatar
vietti
my 2004 does the same thing and has from day one. replace termostat and gasket twice.. still does it..its a very small leak though. few drops an hour at most..
Old Oct 28, 2012 | 09:10 AM
abarmby's Avatar
abarmby
Don't know if this is a contributing factor or not but....the Tstat housing is supposed to fit one way on the 5.7.
It should have "front" stamped on it Si it faces forward.
Just a thought??
Old Oct 29, 2012 | 10:54 AM
gunbunny2bg4u's Avatar
gunbunny2bg4u
Make sure you tighten the houseing evenly, 1/4 turns at a time. If not in can warp the houseing and put uneven persser on the gasget and the leak in a short amout of time.
