Injector change will not start
Old Nov 8, 2012 | 11:59 AM
DB1967's Avatar
DB1967
Default Injector change will not start
I have a 2006 Ram 3500, and it started running bad, very weak, had it diagnosed and the #5 injector was bad. I changed it and started it up, ran a minute or so and died, and will not start. I bleed the primary pump and injector lines, but still will not start.
Any suggestions, before I have it towed to the dealer?
Daren
Old Nov 8, 2012 | 01:25 PM
DodgeCACares's Avatar
DodgeCACares
Daren
Daren,
How long has the truck been running bad for prior to the diagnosis? Did your Dodge dealer diagnose the problem as the #5 injector or was it taken to an independent?
If you'd like to PM me your VIN#, I can look into this for you to see if there is addition information or assistance I can provide.
Old Nov 8, 2012 | 01:37 PM
Izero's Avatar
Izero
Is this a gas or diesel engine?
If it is a diesel you should have this thread moved to the diesel section of this forum, they would be able to help you better there.
Old Nov 9, 2012 | 09:52 AM
DB1967's Avatar
DB1967
Sorry, not to savy with this website. I will need admin to move it to the Diesel section for me.
