04 ram hemi bog down
Old Nov 11, 2012 | 11:05 PM
robgtx90's Avatar
robgtx90
Exclamation 04 ram hemi bog down
i have a problem that my 04 ram hemi has
i start my truck and once it idles down to idle rpm it boggs then shuts down ...then i start it it runs fine but once i go to put it in to gear it boggs again then i restart then fine after putting it in to gear but once i go to press the gas to move ....it moves but oce i go to come to a stop and i let off the accel it will bogg down and almost die but sometimes keep running after a bogg down .................................................. .............any ideas ......the egr and TB and IAc was all replaced
Old Nov 12, 2012 | 07:41 AM
Izero's Avatar
Izero
Please list the mileage and ANY/ALL modifications you've installed on the truck...
Also do you have any DTCs? (Diagnostic Trouble Codes aka Check Engine Light)
If you do, please use a scanner OR the key method to get them, and please post them up IN THE ORDER THEY APPEAR.
Old Nov 12, 2012 | 12:34 PM
willdikem66's Avatar
willdikem66
Have you done a simple tune up?
Old Nov 12, 2012 | 01:37 PM
robgtx90's Avatar
robgtx90
i have checked the DTC and There are none showing and no mods have been done to the motor or ecu and i have been doing the usual tune up evry 5000k and have replaced the cv axle last month and nothing else and the km that are on it are 162,674 km
Old Nov 12, 2012 | 02:20 PM
willdikem66
Well you said you do the usual tune up at 5,000 miles, so that means you have changed your plugs how many times now and when is the last? Odd that there are zero DTCs those are what really help point out the problem.
Battery is good? All the Grounds are Good?
Old Nov 12, 2012 | 05:13 PM
robgtx90's Avatar
robgtx90
battery is brand new the grounds are good ( frame ground body ground) positives are cleaned and the plugs were changed in the summer time i havnt drove this truck since............. but the start prob still ecsists
Old Nov 13, 2012 | 08:14 AM
Izero's Avatar
Izero
Okay so you've got about 101,000 miles for us Americans.... lol
If the car sat for more than 4 months, you might be experiencing a clogged fuel system [somewhere] due to the ethanol in the fuel breaking down and creating sediment in the tank, which might be clogging the lines.
You need to check the fuel pressure, if you are below 50 PSI you've found your problem and you'll likely need to drain the fuel tank, get in there and clean it out (or you can try some fuel cleaners but they usually don't do the trick...), change the fuel pump & filter, and you might even have to change the fuel lines up to the rails... injectors could also be clogged.
So let's start by checking the fuel pressure at the fuel rail, be careful not to blow yourself up...
Also what plugs did you use? Platinum? Iridium? or Copper? or something else?
Old Nov 13, 2012 | 02:08 PM
willdikem66
Is it to late for Sta-Bil or Star Tron?
Old Nov 13, 2012 | 02:18 PM
Izero's Avatar
Izero
well those usually prevent the ethanol from breaking down, or at least slow the process considerably, so it wouldn't hurt to try it, but it might be too late.
There are products out there that might help, but I just can't remember the name of them off the top of my head, so I'll have to do some "trolling of the interwebz"..... lol
Old Nov 13, 2012 | 02:19 PM
willdikem66
I figured that would be the answer
