3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
He can't get the truck started yet, so doing that is a little impossible at the moment, but if the new battery gets the truck running, I would definitely agree he should have that done....
The "chunk" noise is probably the starter engaging but doesn't have enough power to turn the transmission. The "chatter" is the starter gear not fully engaging. Wiring is probably good since something is happening. Problem is either battery, starter, or both. Good news is that they are easy to replace.
