P0340, P0344 and stalling
Old Nov 19, 2012 | 09:52 PM
c.c.w.'s Avatar
c.c.w.
Default P0340, P0344 and stalling
2003 Dodge Ram 1500 2WD 4.7
P0340 & P0344 codes. Vehicle will occasionally stall out unexpectedly. Not sure if this is a symptom. I changed both crank and cam sensors but problem came back after 2 weeks. Did I read somewhere that you MUST use OEM sensors as well as re-flashing the PCM?
Class? Anyone?
Old Nov 21, 2012 | 10:13 PM
c.c.w.'s Avatar
c.c.w.
Problem solved. Close please.
Old Nov 21, 2012 | 11:37 PM
Bryanh's Avatar
Bryanh
What was the cause of the problem and what did you do to fix it?
Posted from Dodgeforum.com App for Android
Old Nov 22, 2012 | 12:22 AM
redram2007's Avatar
redram2007
for someone that might need it in the future
Old Nov 25, 2012 | 12:48 PM
c.c.w.'s Avatar
c.c.w.
Dodge evidently did not release electronic sensor schematics to the aftermarket so Mopars and aftermarket sensors are a crap shoot and generally do not work well, if at all. Only use factory Mopar sensors.
