conversion box that joins the separate blinker/ brake tails to a single blub
Old Nov 22, 2012 | 04:11 PM
DodgeZ's Avatar
DodgeZ
Default conversion box that joins the separate blinker/ brake tails to a single blub
I am converting my 05 Ram to 07 Ram lights. The 05 has different blubs for the brake and turn signal. The 07 uses one blub. If you wire the brakes and turn in to the same blub the turn signal doesn't work if you have the brakes on.
What is the best way to fix this?
