Interior LED problem.
I just replaced my map lights with festoon LED bulbs.
When I turn one on it only comes on very very dimly. If I turn the second one on at the same time they both light up full brightness.
Do I need to add a resistor in somewhere so I can turn a single light on and off without having to turn them both on?
Does the resistance of the LED have to be equal to the bulb that WAS in the socket prior?
I'm thinking I can just drop in a resistor beside the festoon bulbs, or solder a resistor to the festoon leads.
that is first semester stuff.....
in my defense, I haven't measured a diode since then
Trending Topics
lol all good bud... I cant tell you I have a hard time remembering all the Calculus and even some of the efficiency calculations and what not, but I kept all my important textbooks and notebooks so it's all good
You can get a resistance reading over a diode if you have a nice fancy multimeter that has the ability to generate voltage to measure resistance across a circuit... they are usually more accurate too.
Anyways go measure and try a resistor that matches....
I kept all my stuff for the same reason, I'll never remember half of this stuff lol.
So I need to match the resistance of the LEDs bulbs I'm using?? the original bulbs measured around 2.2-2.5Ohms, but I'm thinking I should check the current draw from them, measure the actual voltage of the truck and calculate the resistance.
I guess I just don't understand why the resistance of the LEDs need to be matched with a resistor. Shouldn't I be trying to achieve the resistance of the original bulb?
