2006 dodge 1500 hemi cranks but wont start
Old Dec 10, 2012 | 10:43 PM
cr250foxx's Avatar
cr250foxx
Exclamation 2006 dodge 1500 hemi cranks but wont start
ok i have a problem i can not find an answer so hopefully someone has had the same problem and can help.
yesterday i went out hunting in a corn field. on the way home my truck kinda shuttered but didn't die and went right back to normal, i look at the gauges nothing so wrong no check light came on, no temp or oil lights and the truck never did it again all the way home. That night i did a little running around and nothing until this morning.
my wife went to go to work and it wouldn't start. I came home and it had a check engine light the code was p1521 which deals with the oil. i cranked it and sprayed a little ether to check if it was a fuel problem but still no fire. which brings me to spark i have none. i was told it could be a camshaft sensor or crank sensor i replace to crank one first only because i was driving through corn thinking i might have hit something and it is located closer to the ground. i havent done the cam shaft sensor yet. just want to get some feedback before i did. if you knows anything please let me know
