2002 dodge ram 4.7..only half the engine runs!? HELP!
Old Dec 17, 2012 | 07:08 PM
Bradley Foster's Avatar
Bradley Foster
Exclamation 2002 dodge ram 4.7..only half the engine runs!? HELP!
Ok guys, I'm new to this forum. My name is Brad. And before i say anything, i appreciate anyone who reads and gives me any insight to my issue at hand. I own a 2002 dodge ram 1500 4.7 with 211,000 miles. For some odd reason, it is running on only the 4 rear cylinders. I've put all brand new OEM coils, OEM plugs, and 4 new injectors. I honestly cannot figure out what the krap is going on. I've checked the heads, there is no rockers that have failed, and i do not think its valve issues..hopefully. But when you start it, you have to open up the throttle to start it once it warms up, due to it over loading the front half of the motor with fuel im guessing. Once it is running, the further you rev the engine, the 4 cylinder miss actually seems go away i think. My father seems to think that prehaps i have a faulty cam/crank sensor and that i should change both. What do you all think this issue may be? Anyone ever had this kind of issue? I need help quick as this is my winter truck. thanks!!
Old Dec 17, 2012 | 08:50 PM
Bradley Foster
Plase guys. I really need help
Old Dec 17, 2012 | 08:57 PM
scwpd's Avatar
scwpd
What codes are showing
Old Dec 17, 2012 | 09:20 PM
Bradley Foster
Oddly..none. but the light is on??
