Replacing U-Joints on 05'
Old Dec 19, 2012 | 10:40 PM
itsUhHemi's Avatar
itsUhHemi
Default Replacing U-Joints on 05'
So I will be replacing my U-Joints tomorrow on my 2005 regular cab. Has anyone does this? Any tips/suggestions?
Old Dec 20, 2012 | 10:24 AM
p38251's Avatar
p38251
Buy a good quality replacement, that is greaseable. Are you using a press? or old school beat them out. becareful not to bend the ears if using a press.
Old Dec 20, 2012 | 11:46 AM
itsUhHemi's Avatar
itsUhHemi
Yeah I will be using a press. Trying to get the bolts off the rear right now.
Old Dec 24, 2012 | 01:48 PM
shock5's Avatar
shock5
If you are working on the front shaft use a little heat it will help break them loose.Good luck!
Old Dec 31, 2012 | 05:06 PM
blacktop's Avatar
blacktop
just an fyi -If your making big HP the nongreaseable u-joints are stronger because they aren't hollow.
