?? About Defrost Mode
Old Dec 22, 2012 | 05:52 PM
DBHMEH's Avatar
DBHMEH
Default ?? About Defrost Mode
I have ab 06 Ram 2500 Diesel. I am almost positive the A/C light came on when put in the defrost mode. It is no longer coming on. I believe I hear the compressor engage. The air flow is not that strong, but it does transition to all positions. Is that light on the A/C button supposed to come on? If it is any suggestions?
Thanks David
Old Dec 22, 2012 | 09:42 PM
HemiLonestar's Avatar
HemiLonestar
Usually the light doesn't come on, but the compressor is engaged for defrost to reduce the moisture.
Old Dec 23, 2012 | 09:00 AM
Gone Fishin's Avatar
Gone Fishin
If you had the A/C (button on) before you went into defrost, the light will illuminate, if it was not running the A/C (button off) prior, it won't.
Old Dec 23, 2012 | 12:38 PM
DBHMEH's Avatar
DBHMEH
Thanks so much,
