Engine Temp jumpin around
Old Jan 1, 2013 | 12:00 AM
Nate_sorenson's Avatar
Nate_sorenson
Default Engine Temp jumpin around
so its 3 degrees out i head to work, truck hasnt been started all day. on about minute 8 of my 15 minute drive check guage light pings at me i look over and the needle is pegged on high, stayed there the rest of the way to work, just got home and all throughout town it jumped around. and then on the way home it stayed in the middle every once in a while dropping below center, whats goin on?
Old Jan 1, 2013 | 05:36 AM
abarmby's Avatar
abarmby
Thermostat??
Coolant leak??
Leak in system causing air and temp probe pegging out??
Water pump??
Start at the easy stuff and work through.
Al
Old Jan 1, 2013 | 09:43 AM
p38251's Avatar
p38251
Sensor
Old Jan 2, 2013 | 07:55 PM
Wanderer's Avatar
Wanderer
Maybe some ice got caught in the thermostat? How old is the coolant and if it's a reasonible age, have you checked the the protction level. Could have formed some ice that got caught somewhere, slowly melted and coolant flow returned to normal. Truck is 10, going on 11 years old. When was the last flush and replace. Look for the simple things first.
3 degrees already, guess I'm getting spoiled here in mountains of Jersey. So far the low this season has been 15. Of course we did have a damaging snow storm in October and Sandy in November.
Old Jan 2, 2013 | 09:57 PM
MikeHTally's Avatar
MikeHTally
At three degrees, there should be no ice in the coolant, unless the coolant is below standards anyway.
Old Jan 3, 2013 | 06:53 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would check the coolant level if you havent already
