2005 Ram 1500 Factory amp?
Old Jan 1, 2013 | 01:30 AM
Crazkilljoy's Avatar
Crazkilljoy
Default 2005 Ram 1500 Factory amp?
What in god's name is it? how many amps does the thing put out? I put in a Kicker amp and sub, but only for bass. I'm going to replace all the 6x9's and 5-1/4's with kicker but want to know how much the factory amp puts out.
Thanks
Old Jan 1, 2013 | 04:22 PM
itsUhHemi's Avatar
itsUhHemi
Not sure how many amps it puts out however I can tell you they are a pain in the rear when you install aftermarket stuff. I had to completely bypass it when I installed speakers in my 08'.
EDIT: That's if you are talking about the infinity system.
Old Jan 2, 2013 | 10:24 AM
DodgeDanny426's Avatar
DodgeDanny426
If you have the infinity package there is an auxiliary amp pushing a much greater RMS rating than any headunit amp out there - there are no definitive answers I can find as to the actual power rating on this. However I can tell you that the factory headunit pushes anywhere from 20-35 watts peak and 10-15 watts RMS.
