Heater Help
Old Jan 5, 2013 | 07:42 PM
PACowboyfan's Avatar
PACowboyfan
Exclamation Heater Help
I am puzzled. My heater/ac blower was working intermittently on all settings. Then it stopped working all together. I replaced the blower moter resister and this did not correct the problem. I checked all fuses just incase it blew the fuse but no luck, all fuses are good. I have a 2008, 1500, 4.7 l, 6 spead, truck, any suggestions?
Old Jan 6, 2013 | 05:46 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
replace your ignition switch
serioulsy
Old Jan 7, 2013 | 11:33 AM
PACowboyfan
Default Thank you
Thank you, I will try that this week and see how it goes.
Old Jan 15, 2013 | 09:42 AM
PACowboyfan
Default Still Looking
I have replaced the starter switch and that did not do the trick, it now works sometimes. It seems it want to work only when it wants to. The only thing I can think of at this point is a bad ground wire somewhere.
