02 Ram 4.7 1500 timing tensioner problem
Old Jan 14, 2013 | 03:59 PM
ssiroin's Avatar
ssiroin
Default 02 Ram 4.7 1500 timing tensioner problem
Howdy, I recently replaced my timing tensioners on my o2 Ram cuz of slap. I simply replaced the left and the right, and then did the main tensioner on the bottom. I pulled the cam drive gear, installed new tensioner and replaced the gear. Now I have a no run situation. I have spark, fuel in the rail, signal at the injectors. I can make it run without a backfire by squirting card cleaner down the intake throat. I have to say that I did not remove ground from battery while doing this. OOPS. Any ideas will be appreciated. Thanks.
Steve
