Front Bumper Questions
Old Jan 17, 2013 | 12:33 PM
ItsAVROD's Avatar
ItsAVROD
Default Front Bumper Questions
I am able to get a fair price on a Ranch Hand style front bumper. The seller says that he spoke with a local Dodge dealer and the bumper will mount as is to all models (1500, 2500, 3500). Does anyone have first hand knowledge if a 2007 2500/3500 bumper would be compatable with a 2007 1500?
Old Jan 17, 2013 | 02:21 PM
08HEMI1500's Avatar
08HEMI1500
I have heard of the 2500/3500 having different mounting brackets but I don't see why it wouldn't work. The ranch hand will add weight to the front though so you may want to compensate for that as well
Old Jan 17, 2013 | 02:40 PM
Cthulhu's Avatar
Cthulhu
Might want to watch the weight you put on the front of a 1500 with the IFS though.. 2/3500s havea a solid front axel, which is much more durable...
Old Jan 17, 2013 | 04:07 PM
ItsAVROD's Avatar
ItsAVROD
Good points. Any estimate at what weight it could really become a concern? 150#? 200#?
Would the main concern be part ware? Or would it be the front drooping/sagging causing the need for a leveling kit/lift?
Old Jan 17, 2013 | 04:27 PM
omextreme's Avatar
omextreme
I can tell you that the 1500 has welded frame mounts for the front bumper that cannot be removed. the 2500 3500 has a bold on frame mount. If the ranch bolts to the mount youll be fine if it bolts to the frame direct you may have issues.
Old Jan 21, 2013 | 02:36 PM
Cthulhu's Avatar
Cthulhu
Accellerated wear of suspension points (ie Ball Joints, shot mounts, A arm (I think that's what they are called), hubs..
I don't know where the limit would be... I'll leave that for someone with more knowledge to give you an idea on that.
