check engine light on code po305?
Old Jan 23, 2013 | 04:32 PM
swamper's Avatar
swamper
Default check engine light on code po305?
my check engine light is on i had advance pull the code for me and the code is po305 they said cylinder misfire...would you say that its a bad spark plug or bad plug wires?
Old Jan 23, 2013 | 07:58 PM
p38251's Avatar
p38251
cylinder 5 miss fire. if it has been a while plugs would be a good start. maybe a compression check on that cylinder as well
Old Jan 24, 2013 | 02:32 AM
scwpd's Avatar
scwpd
Check pkugs and wires(if you have them) and replace if needed if the cel comes back move the coil to a different cylinder to see if it follows the coil or stays on the same cylinder
Old Jan 26, 2013 | 04:51 PM
swamper's Avatar
swamper
ok thanks its been so cold here i didnt the chance to change the plugs and wires yet.but now last night the check engine light went off.why would it go off?
Old Jan 27, 2013 | 06:43 AM
swamper's Avatar
swamper
bump.
