Headers and pre 02
Old Jan 27, 2013 | 07:50 AM
03 RamHemi Toy's Avatar
03 RamHemi Toy
Default Headers and pre 02
I put pacesetter long tube headers on my truck and put ths sensors pre and post in position on the right, I'm getting 02 high voltage code on the scanner. Do I need to place two more on the left and splice then to the harness to get a lower reading?
Old Jan 27, 2013 | 12:58 PM
T-Muns's Avatar
T-Muns
So you kept your cat and tapped a hole for the downstream O2? Your 2003 only needs one of each, no need to do left side. What exact codes are you getting?
Old Jan 27, 2013 | 02:27 PM
03 RamHemi Toy
The headers are tapped for the upstream and new cats are tapped as well I assume is for the down stream. You think I may have the pre 02 in the wrong place? Should the upstream go in the cat? I don't remember the number of the code just 02 voltage high
