side view mirrior
Old Jan 29, 2013 | 08:34 PM
4.7Ram's Avatar
4.7Ram
Default side view mirrior
i have a 2007 dodge ram and im looking for som tow mirriors simply for the look since i dont like the look of the stubby mirriors i have stock, well a guy on craigslist is selling both tow mirriors from a 2009 ram for a 100 bucks and 2012 ram for 45 bucks, they are both power and heated like i need but im wondering if the pigtails will match as well as the bolt pattern?? yall have any idea
Old Jan 29, 2013 | 08:36 PM
rtmtrrdr's Avatar
rtmtrrdr
most likly no the won't fit.completly different body styles
Old Jan 29, 2013 | 09:32 PM
KasperR34's Avatar
KasperR34
Not necessarily true; the Third gen fit on 2nd gens
Old Jan 30, 2013 | 09:13 AM
kenneymc's Avatar
kenneymc
I would think the easiest way to check is to look up the part numbers for the mirrors for the donor vehicle, then look up the part numbers for your vehicle. If the same, should be ok. If not, then I would think that they would not fit properly.
Old Jan 30, 2013 | 09:55 AM
DodgeCACares's Avatar
DodgeCACares
4.7Ram,
Do you have power and heated mirrors already? If you don't then you will not have the wiring there to install it, however it is hard to confirm if the mounting would be the same. I would recommend getting the part#'s you are looking to purchase and contact a Dodge dealer. They will be able to advise if the parts are compatible, as they will have all of your vehicle information, and point you in the right direction.
Old Jan 30, 2013 | 10:09 AM
Izero's Avatar
Izero
If he has heated and power mirrors then all he'll need to do if the plugs are different is cut and splice the old pigtail to the new mirror... not too hard with a multimeter and some time...
