Cams for a 2003 5.7
Old Feb 4, 2013 | 02:14 PM
tex76513's Avatar
tex76513
Default Cams for a 2003 5.7
so looking to put some Cams on my Dodge it is a 4WD, but i am trying to get some suggestions on what are good cams for horsepower, i have the 2 single overhead cams i think right now from the factory but want more horsepower so any suggestions will be great.
Old Feb 4, 2013 | 11:48 PM
Old Man with a hemi's Avatar
Old Man with a hemi
I'm rather stunned that you have an overhead cam in a modern hemi, since they are ohv pushrod engines, and you will only need one cam, not two. If yours is different, I'd say you will have a hard time replacing the CAMS in your 5.7
Old Feb 5, 2013 | 09:08 AM
tex76513's Avatar
tex76513
well i ain't to familiar with dodge so i really appreciate the advice you just gave me cause i assumed it had cams but thank you for the help with that.
Old Feb 5, 2013 | 09:39 AM
abarmby's Avatar
abarmby
If your looking for a trouble free easy install a good cam for your heavy 4x4 QC would be a 260.
With the 03 Being the red headed step child of the bunch, tuning options are next to nil.
A 260 grind will run strong out of the box and is 03 PCM friendly. It's a good torque cam to get that heavy *** QC moving.
You can get a custom tune to improve it further, but you won't have any idling issues with a 260 as you would if you ran a more aggressive cam.
03 Hemis cannot have the idle speed adjusted in software in the PCM, so other more aggressive cams are notoriously difficult to do anything with.
But before people chime in, there are some 03's with big aggressive cams in them, but also with considerable support mods as well.
If you wish to go even further with your 03, you can buy an 04 or 05 year PCM and full wiring harness.
A swap with either of them then opens up what everyone above 03's can do with tuning and extensive support. A bigger cam is then no problem as idle and a lot more can be adjusted in software.
It's a big thing to do, so don't start this without deep and thorough research.
Hope all this helps?
Al.
Old Feb 5, 2013 | 11:11 AM
tex76513's Avatar
tex76513
Al,
hey i appreciate everything that you just told me and will look at every option possible for the 03, once again thank you.
Tanner
Old Feb 5, 2013 | 05:14 PM
Old Man with a hemi
Your welcome.
Old Feb 5, 2013 | 06:24 PM
HemiLonestar's Avatar
HemiLonestar
Do you have the 4.7 or 5.7? It sounds like you aren't sure or don't know.
Old Feb 6, 2013 | 09:56 AM
tex76513's Avatar
tex76513
I got the 5.7
