Wet seats :(
So I was digging around on the forum, specifically at the sunroof threads. I have an '06 Ram 1500 MegaCab. Had a pretty decent storm going this morning and when I went to take my son to the bus stop, I sat down and got a wet butt. I looked and water was dripping from the driver side of the sunroof, the back of the sunroof, a spot closer the driver door, and from the driver side a-pillar. It could be dirty sunroof drains, and hubby is gonna investigate when he gets home in a little while (hopefully this storm will quit for a minute so we can mess with it) but what else could it be? I'm not believing that pretty much the whole front corner of my headliner and my seat are soaked because of a clogged drain tube. Any other ideas? Thanks guys
Most likely scenarios would be drain tubes clogged or the drain tube has become disconnected, unless the sunroof is off track or was not closed all the way. The fact that water was dripping from the sunroof seems to indicate very highly it is sunroof related. The amount of water that passes through that area, especially in heavy rain, can create quite a bit of wetness inside the vehicle once a leak occurs. Post back up what your husband finds to be the problem.
