Break lights stay on
Old Feb 8, 2013 | 10:29 AM
riceboyent's Avatar
riceboyent
Cool Break lights stay on
HELLO RAMS
Im having a breaklight problem 06 ram 1500 hemi,full tow packg, they stay on I would like to know what could possibly be my problem ok here I go
With the truck ingitio off:
eveything woks just fine
Soon as I star te truck:
my break lights stay on
1. I replaced the break light switch under break ped.
2. Replaced bulbs
3. Checked that relay is good, and all other fuses
4. Checked the trailor plug
5. My drivers side gets water into the curcuit bord ( blew and dried)
LIKE I SAID WITH IGNITION OFF WORKS FINE
TRUCK RUNNING BEAK LIGHTS STAY ON
PLEASE HELP IM GETTING FUSTRATED
Old Feb 8, 2013 | 11:54 AM
dirtydog's Avatar
dirtydog
Moderate User
So, you turn ignition to run but not start, all dummy lights go out along with the brake light? and then when you start it up it comes back on?
Does it flash while your driving? If so, that's your parking brake sensor. Check the ground on your parking brake. If the ground is loose or the switch portion of it is bad then the brake light will flash when in motion. I believe you should hear a chime as well??
I would check your fluid level inside the master cylinder reseviour under the hood. Your probably low. If so, then you have a small leak somewhere. I'd flush all old fluid out in an 06 anyways. Nobody ever does it and it's really due every 30kmi to keep fresh as it absorbs moisture and rusts out calipers and lines from inside out plus it reduces braking performace drastically.
