Front end leveling
Hey guys i just bought the rancho quick lifts for the front of my 2006 dodge ram 1500 5.7. And bilsteins for the back. Anyone have the size of the socket size i will need for everything. Also the torque specs for ones that need proper torque. Thanks for the help! Also any tips & tricks are greatly appreciated!
Chris
Chris
I dont remeber the specific socket sizes but you will need a small variety of them for everything. I also did the quick lifts with the new coil spring as well and I like them. You might run into some stuck or seized bolts so make sure you have a good breaker bar and a good impact gun.
I can try and look up some torque specs later when I have access to the information.
Here is what I got from Alldata, let me know if I can help with anything else.
Upper Suspension Arm Ball Joint Nut- 54Nm/40Ft.lbs
Shock Absorber Upper Nut (4x4)- 61Nm/45Ft.lbs
Shock Absorber Lower Bolt (4x4)- 210Nm/155Ft.lbs
Shock Absorber Upper Nut (4x2)- 54Nm/40Ft.lbs
Shock Absorber Lower Bolt (4x2)- 35nM/25fT.lbs
Lower Suspension Arm Frame Nuts (4x2&4x4)- 204Nm/150Ft.lbs
Lower Suspension Arm Ball joint Nut (1500 series only)- 52Nm/38Ft.lbs
Upper Suspension Arm Frame Nuts- 176Nm/130Ft.lbs
Stabilizer Bar Frame Bolt- 61Nm/45Ft.lbs
Stabilizer Link Lower Control Arm Nut- 102Nm/75Ft.lbs
Stabilizer Link Stabilizer Bar Nut- 27Nm/20Ft.lbs
Hub/Bearing Bolts- 163Nm/120Ft.lbs
Tie Rod End Nut- 61Nm/45Ft.lbs
