New to forum and have a few serpentine belt questions (Squealing)
Old Mar 11, 2013 | 10:00 PM
Ric Catlin's Avatar
Ric Catlin
Angry New to forum and have a few serpentine belt questions (Squealing)
I replaced the water pump in my 2004 dodge 2500 because of a leak and a loud squealing noise. I figured it was all the coolant that had got into the automatic tensioner or one of the pulleys that was making the noise. So i replaced that and the other two idler pulleys and its still squeaking. Any idea what it could be. Its not a belt squeal its coming from one of the pulleys on another part. I bought a new power steering pump but I dont want to replace it if I dont have to. Any ideas??? Please help this noise is driving me insane. I noticed that at an idle it quiets down and then as you accelerate it gets a lil louder and continues to squeak. Its a crunchy noise.
Old Mar 12, 2013 | 07:18 PM
Axle Eighty's Avatar
Axle Eighty
I certainly don't claim to be an expert but if it were me I'd go to harbor freight, buy a $10 mechanics stethoscope and use that to listen for which pulley is screaming. With the motor running, touch the probe near the individual pulleys, not on the spinning wheel. You should be able to pick up the specific whine from a point near or a non spinning pulley bolt.
Old Mar 13, 2013 | 07:34 PM
p38251's Avatar
p38251
Take the belt off and spin each pulley by hand. With it being quiet may help pin point problem.
Old Mar 13, 2013 | 09:50 PM
MoparPaul's Avatar
MoparPaul
Did you change the belt when you did the Water pump?
The reason I ask is some brand of belts have steel cords that when exposed will cause a annoying squeak. Double check the edges of the belt.
