P0155 2004 Ram 1500 5.7l
Old Mar 17, 2013 | 09:38 AM
Amerce's Avatar
Amerce
Default P0155 2004 Ram 1500 5.7l
So I recently bought the truck and posted about the misfire problems, turns out the guy before me put platinums in it, got rid of the misfires with copper plugs.
I'm still throwing p0155 code (o2 bank 2sensor 1) even though I've replaced both upstream sensors with mopar sensors.
One mechanic told me I need a pcm without even looking at it and another said it has to be either a short or an exhaust leak. My manifold on the right side does have a leak so I'm trying to figure out if I should be purchasing a new manifold or pcm?
Any help is much appreciated
Old Mar 17, 2013 | 05:57 PM
gunbunny2bg4u's Avatar
gunbunny2bg4u
eather way you need a new manifold. do that first and then see what happens after you clear the codes. I doint think the computer is at fault.
Old Apr 13, 2013 | 09:53 PM
Amerce's Avatar
Amerce
Bolts were cracked in the manifold, i just had them taken out and new ones put in, it no longer leaks.
The new upstream sensors are both mopar from the dealer.
Drove the truck about 18 miles with no code after fixing the manifold. Stopped at a light and floored it just to hear it without the leak and got a CEL for Low Barometric pressure P0129 and the O2 code again P0155, immediately reset them. 8 Miles later I got the O2 code again P0155.
PLEASE HELP?!
Old Apr 14, 2013 | 01:34 PM
p38251's Avatar
p38251
p0155 is the heater circuit. The o2 may still work. Possable bad o2 from the dealer, Your call the only way to fix the heater circuit is to replace the o2 sensor.
Old Apr 15, 2013 | 09:14 AM
Amerce's Avatar
Amerce
I've replaced the sensor, and I've tried switching the sides of the new sensors and it still only throwing the one code so it can't be a broken sensor
Old Apr 16, 2013 | 08:00 AM
p38251's Avatar
p38251
Check the wiring coming from the truck to the sensor.
Old Apr 16, 2013 | 03:03 PM
cuda19791's Avatar
cuda19791
If you have ruled out the O2 sensor then its your wiring or your PCM.
