U1418
Old Mar 21, 2013 | 01:28 PM
HemiRam1566's Avatar
HemiRam1566
Default U1418
got this code the other morning, abs light, track control light came on, and track control kicks in occationaly when im driving and theres no wheel slipage, i installed a new right rear speed sensor and it didnt solve the issue, any input as to what this could be?
thanks
Old Mar 21, 2013 | 01:53 PM
Izero's Avatar
Izero
99% of the time this is a broken wire leading to one of the speed sensors.
You will have to trace each speed sensor wiring harness to see if there are any wires that are broken.
If not then it's most likely just a speed sensor that broke.
Old Mar 22, 2013 | 07:01 AM
HemiRam1566
well i replaced the right rear sensor hoping to cure the problem but no luck, from a quick check the wiring looks ok to that sensor, im going to pull the wheel and brakes tonight and have a look at the tone ring, i have seen them crack before and cause a code and MIL, dose anyone have the diagnostic procedure for checking the harness, abs modual ext? i need to get this sorted out, was suppose to head north after work tonight snowmobiling but it dosnt look like i will be going, i pulled the abs fuse(fuse location 13 in the underhood fuse panel) and i have no MDS no spedo, no abs, no track control, but at least i can get to work and back with out the trac control kicking in while driving.
thanks
connor
Old Mar 22, 2013 | 11:24 AM
DodgeCACares's Avatar
DodgeCACares
Connor,
I have sent you a PM, let me know if you have any questions.
