Tire Size with lift
Old Mar 21, 2013 | 04:52 PM
aggie4life's Avatar
aggie4life
Default Tire Size with lift
If i added a 6 inch Rough Country Suspension Lift and 3 inch Performance Accessories Body lift.
Would i be able to run 37 x 12.50 x 17 inch tires? I have 17 x 8.5 wheel with a plus 10 offset
Would 4.56 gears be the best option for those size tires?
Would a body lift effect my ability to run a Ranch Hand Grille Guard?
Old Mar 21, 2013 | 05:31 PM
08HEMI1500's Avatar
08HEMI1500
You'd barely cut it with 8.5 wheels. The tolerance is 3 inches +/- an inch. I'd look for at least 9" wide wheels if you plan to offroad or air down the tires at all. As for the gears I would say yes because those size tires will bog down the engine. Idk about the grille guard but if it attaches to the frame at all then I would say no it won't
