Need advice on my truck
Old Apr 7, 2013 | 09:52 PM
garthed's Avatar
garthed
Default Need advice on my truck
This is a great site. I'm looking for some advice..
I recently purchased a wildwood 26tbss travel trailer. It's 5760 dry and I estimate it to be around 7000 loaded up. I have a 2006 dodge mega cab ram 2500 4x4 with a hemi and 3.73 gears. I bought the truck a few months ago i really like the truck. But....the previous owner installed a 6 inch lift with 37 inch tires on it.
It's a dog. It's not to bad around town but on the highway it's going in and out of o/d all the time and I'm not even towing anything. At 60 mph I'm only at about 1400 RPM. This weekend was our first camping trip with the truck and trailer. I was going from sea level to about 2500 feet. This was a gradual climb with only a few good inclines. The truck was really struggling and even went into 1st a few times :Wow1:
My question is should I put 4.56 gears in. I have an appointment this week to get them done but its going to cost me $1700. I'm afraid that with these big tires the 4.56 still won't be enough.
What is your advice? Is a new truck in my future?
Thanks
Old Apr 7, 2013 | 10:14 PM
hemi4109's Avatar
hemi4109
4.56 would only bring your 1400rpm to around 1700 but I imagine this is in OD. Probably want to be 2100-2200+ or so minimum to pull the trailer and 4.88's might be a better match for 37" tires. The Hemi has lots of power to haul around a combined weight of around 13500 lbs but not anywhere near those low rpms. I do all day long on OD when hooked up but I don't have anywhere near 37" tires!
Old Apr 7, 2013 | 10:41 PM
garthed's Avatar
garthed
Thanks for the reply. I weighed my truck and it ways a little over 7000 empty. I'm traveling with my wife, two kids, dog, a few bikes, and a couple armfuls of wood. So maybe around 7500 loaded. With trailer I'm thinking I'm at around 14500 pounds I was told that 4.56 was the lowest gears that fit in the front axle.
Old Apr 8, 2013 | 08:46 AM
04HemiGreg's Avatar
04HemiGreg
If you are going to be hauling a trailer often, you would probably be better off dropping the truck back down with smaller tires. Not all the way and I know it sucks and wouldn't be cheap but a jacked up rig and towing are hard to fit together. Mine is leveled and I am running 34's but I have load rated tires and I didn't want to go bigger because I do tow an rv sometimes.
I have a similar dilemma now because I just got a Chevy hd and I hate the little wheels and tires and that darn rake. I can level it and maybe put some rear blocks on and fit some bigger tires but not as big as I would like. Or I could lift it 6 inches and do what I want but I know that will make towing the rv less practical.
Old Apr 8, 2013 | 08:52 AM
hemi4109's Avatar
hemi4109
I'm not familiar with the front axle on the 2500 so I'm sure you're right. Basically the 4.56's will up your revs by 22% so you can see where that will take you compared to now. I think your tires are just too big to keep your overall ratio up enough to be happy with it. Before dumping 2K+ on gears, any way you can temporarily throw a set of stock wheels/tires on there and see if you like the results? That would be about the equivalent on changing your gears.
Old Apr 8, 2013 | 03:23 PM
p38251's Avatar
p38251
Agree, smaller tires. And re-gear
