Odometer not working....JUST the Odometer..Solution??
Old Mar 27, 2020 | 02:48 PM
  #21
khnitz's Avatar
khnitz
Originally Posted by Steve Dahm
I have a similar problem on my 06 Ram 1500. The odometer quit adding miles awhile ago. My question is if the soldier point is corroded and I clean and reflow soldier will the actual mileage show than? Thanks!
I think the best you can do is judge by the experience of others on the thread here. I tried to touch up solder joints on my cluster, but this did not remedy the display problem for me. For me, the solution was getting it remanufactured/repaired/exchanged via United Radio. But I'm glad to see others had luck with just reflow of joints/components.
Old Apr 16, 2022 | 10:19 PM
  #22
LImarine316's Avatar
LImarine316
Default Repair worked.
Originally Posted by Steve Thames
This is what i found. Corroded, and cold solder joint. Cleaned and re-soldered. Fixed
I just had the same problem with my 04 1500, cleaned and reattached the same part and my Odometer and Gear display are working again.
Old May 5, 2022 | 02:36 PM
  #23
wherring198's Avatar
wherring198
I just beat on the dash hard and it started working again I have an 05 Ram 1500 hemi done same thing just the odometer lights and warning lights went out come back on and hasn’t done since
Old Oct 8, 2024 | 01:59 PM
  #24
Rogueplayer's Avatar
Rogueplayer
Been having the same problem for a few years now. Tried re-soldering the Q5 chip. Didn't work. Reflowed the legs on that white ceramic like you said, voila. Hope it's the final fix. Thanks for posting, gentlemen.
