Have the Hemi Tick? TRY THIS
Old Apr 24, 2013 | 09:53 PM
jnellydodge's Avatar
jnellydodge
Default Have the Hemi Tick? TRY THIS
Ok this topic has been beaten to death then waken up and beaten to death again BUT I have had some surprising results with suppressing the hemi tick using this remedy I would like to share:
Every other oil change (I use Royal Purple, but any quality synthetic should do fine), pour half a can of seafoam into the oil 300 miles before you are going to change it. Without getting too technical; it cleans out all the extra crap that ethanol added fuels deposit into our engines as well as other garbage. I have been doing this since December, and since its almost May now I figured it was safe to share my results. I have NO hemi tick, matter of fact it has been gone since the first half can of seafoam went thru my engine. My oil never looked dirty when I changed it every 5k (again synthetic), but after I used that first half can it came out BLACK.
IF YOU HAVE OVER 100K:
A recent post about a member using this stuff in his 4.7 high mileage motor and then having it stall out on him due to all the contaminants that got knocked loose reminded me about my little experiment. Take care if you have a high mileage engine, I suggest you ween your truck onto this stuff, as it WILL clean out your engine and it CAN clog things up if you over do it.
***I will not be held responsible for any issues/problems that should arise if you attempt this remedy, I am just sharing my what has worked for me (gotta cover my butt)***
