front end lift?
Old May 4, 2013 | 08:22 AM
quadgoose's Avatar
quadgoose
Default front end lift?
Ive been a ford owner for years switched to dodge recently, because its a better built truck. I can say no disrespect intended but ford owners forum was always very helpful with my 77 f250... so far I have not received much help from dodge owners. Maybe it will change with this post:-)
) I have 6 pack of leaf springs in the rear, I just rebuilt the rear axle, and the pinion seal, my question is the front is not raised, and sits level once I jack it up. Does this interfere with the driveline angle?
2) I rebuilt the engine and get the code mismatched vin abs code, the ecm wasnt touch why would one get this abs code? Flash required?
Thanks for any responses to either question.
Old May 4, 2013 | 08:44 AM
rtmtrrdr's Avatar
rtmtrrdr
For the front end there are many ways to level your truck out. Spindles,lift kit,level kit. Everyone has there own opinions on which one is better. I have a 2" level kit from fatbobsgarage.com It does the job, the front and rear are perfectly even.
As far as your other problem I'm not sure. Maybe others will chime in with more info
