idle problems
Old May 11, 2013 | 08:34 PM
robertsahlberg's Avatar
robertsahlberg
Default idle problems
hi I have a ram 1500 2004 5.7 hemi 2 door 2 wheel drive automatic trans.once it warms up,idle drops to 500 rpm, and there seems to be a miss at idle warm or cold. I replaced plugs,wires,crank timing sensor and cleaned mass air sensor.problem still there,any ideas ?
Old May 11, 2013 | 08:57 PM
cuda19791's Avatar
cuda19791
Is the CEL on or flashing? You should have your truck scaned for codes that might tell you where the misfire is then you can find out what the cause of the misfire is.
Old May 11, 2013 | 09:10 PM
robertsahlberg
thx for responding,code came up for #7 coil pack ,changed that along with wires and plugs.as of now no codes but still not running right
Old May 11, 2013 | 09:48 PM
gcburkett's Avatar
gcburkett
Have you cleaned the idle control valve?
Old May 12, 2013 | 05:03 PM
robertsahlberg
hi not yet but will tmrw.didnt no they could be cleaned ,thought only replaced.thx ill try tmrw
Old May 12, 2013 | 05:35 PM
ewing111's Avatar
ewing111
sometimes egr valve can negatively affect idle and how its running. Might be a bit of a longshot, but its only 30 bucks or so to replace.
