camshaft position sensor
Old May 28, 2013 | 09:10 PM
03dodgeram13's Avatar
03dodgeram13
Default camshaft position sensor
I had a code for camshaft position sensor. Changed it. The light went off for a day. Then came back on. I changed 3of them out n light is still on. Any oneqhave any ideas why?
Old May 29, 2013 | 07:43 AM
ewing111's Avatar
ewing111
which code is that?
Old May 30, 2013 | 12:35 PM
03dodgeram13
Camshaft position sensor . I think it was p0304
Old May 31, 2013 | 08:09 AM
ewing111's Avatar
ewing111
You have the 4.7? Could be a rocker arm fell off, you could pull the valve covers and take a look. Thats a common problem on those engines.
Old May 31, 2013 | 12:18 PM
DodgeCACares's Avatar
DodgeCACares
03dodgeram13,
What year is the vehicle that is drawing this code? If you'd like to send me your VIN#, I can review the code for you. However a diagnostic code is to assist in locating a problem; and additional diagnostics tools, which are available to Dodge dealers, may be needed to further assist in pin pointing your concern.
