front suspension broke...
Old Jul 3, 2013 | 08:28 PM
spock-mckoy's Avatar
spock-mckoy
Question front suspension broke...
Hi, I am looking for a diagram/drawing of the front suspension of a 02' 2500 ram 4x4. 360 gas. I've been hearing squeaks and upon a quick inspection, I discovered a broken part. Not sure of the name of it. It is a vertical bolt assembly joining a type of stabilizer rod. The horizontal rod assembly is fine and is about 1.25" in diameter, but the broken vertical bolt assembly looks only about 3/8"-1/2" dia thick. There are rubber bushings with this vertical bolt assembly too to add to the description. I would like to order new parts, but I will need a definite proper name to look up the parts. Thanks in advance.
Old Jul 3, 2013 | 08:38 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Is the bar straight then kind of curve up then down a bit?
Old Jul 3, 2013 | 09:20 PM
spock-mckoy
Default pic of broken part
https://plus.google.com/photos/111727459523755336177/albums/5896563457531119953/5896563457356206290?authkey=CJPLm6GYhdyuKA&banner= pwa&gpsrc=pwrd1#photos/111727459523755336177/albums/5896563457531119953/5896563457356206290?authkey=CJPLm6GYhdyuKA&banner= pwa&gpsrc=pwrd1&pid=5896563457356206290&oid=111727 459523755336177
the vertical rod in the center of the pic is what is broken at the base, inside rubber pieces. the vertical rod appears black in the center of compared to other parts around it. It is just to the right of the coil spring.
Old Jul 3, 2013 | 09:33 PM
dodge dude94
Oh, that's a sway bar endlink. You're going to need two of those guys. Likely they'll come as a pair, granted I haven't looked in a while.
And your front axle is a Dana 60.
Old Jul 3, 2013 | 09:34 PM
spock-mckoy
Default thx
Hi, thanks for the info. I will search the web now. I don't know if the forum has a fav site to get their parts or not?
Old Jul 3, 2013 | 09:38 PM
dodge dude94
Rockauto.com
Old Jul 3, 2013 | 10:20 PM
spock-mckoy
Mevotech MK7453 $22.79 each x 2. Checked other sites, Rockauto beat them. Thanks again.
