At the end of the line, Need Help
Old Jul 15, 2013 | 01:14 PM
shspeed's Avatar
shspeed
Default At the end of the line, Need Help
This is my first post. I have read many, many helpful other posts. I have an 03 Ram 2500 With a 5.7 Hemi. It has been nothing but a pain the last two years. Started with overheating issues. Changed, T-Stat, Rad. Cap, Water Pump. Had no heat, cleaned heater core out. Got heat, but no hot air on defroster. It does have two broken bolts on the passenger side of the exhaust mainfold. Could this blow enough heat up to make the motor run hotter? Next question, Is there a way to pressure test the radiator at home? Clutch Fan, test for at home? This truck has been nothign but problems the last two years. Mainly the over heating, but it also did an 02 front sensor code again. I've put two on in the past two months. First was an after market. Second was an OEM. Any help or suggestions would be greatly appreciated. Just a note, The trucks runs hot and is losing fluid, always low when I check it. Haven't seen anything in the oil yet.
Thanks in Advance.
Old Jul 15, 2013 | 03:10 PM
chromed95's Avatar
chromed95
should probably post this in the 3rd gen section
Old Jul 15, 2013 | 04:10 PM
I will move this to the 3rd gen Ram section.
Old Jul 15, 2013 | 04:56 PM
SteveR's Avatar
SteveR
Warm it up a little to get the t-stat open and then turn it off. Feel all over the radiator to see if it's hot all over or has cold spots. If it has cold spots it is plugged up and needs replacing.
Steve
Old Jul 15, 2013 | 07:33 PM
kenneymc's Avatar
kenneymc
What about any kind of white smoke or steam out the tail pipe ? Losing fluid like that, it's going somewhere. If the is no obvious leak some where I would be thinking cracked head or head gasket.
Old Jul 16, 2013 | 07:23 AM
rought's Avatar
rought
fan clutch should be ready for replacement by now..
Old Jul 16, 2013 | 12:47 PM
shspeed's Avatar
shspeed
The overflow always had a leak around the top. Never over heated though, untill lately. Checked the radiator last night. Was cold on one side, but not other. Will have a new one tomorrow. Also replacing the overflow.
On the overflow leak, as it gets hot, it is losing fluid out the top. Nothing out the tailpipes, and didn't see anyhting on oil dip stick last night.
Old Jul 16, 2013 | 11:11 PM
kenneymc's Avatar
kenneymc
Ahhhh ok. Sounds like you may have found it then. Partially clogged up rad. Let us know how it does after rad replaced.
Old Jul 17, 2013 | 07:00 AM
MikeHTally's Avatar
MikeHTally
When does it run hot, highway or traffic?
Old Jul 17, 2013 | 12:42 PM
shspeed's Avatar
shspeed
This actually does it while driving. I pretty much only use this truck for pulling a trailer on the highway. I have had it get "hot" under normal driving conditions already. But, it doesn't get driven enough dailey to see much happen.
