Performance since new spark plugs
Old Aug 3, 2013 | 08:14 PM
PRF66's Avatar
PRF66
Question Performance since new spark plugs
I let the dealer do some P/M work on my Hemi 2007 Ram Quad 1500. Now, they changed the spark plugs and tranny fluid, filter, and transfer case fluids, nice differential covers. THE PROBLEM, I am experiencing a loss of power when accelerating like the gas pedal pressed and the engine doesnt respond with the zip it once had........like a flat spot. I mean if I tromp on it the truck flies. What gives? Injectors? How can I spot what is causing this performance loss?
PROBLEM 2 the highway gas mileage is down to 13.66 mpg. Never been this low. How can I tell if the MDS is working? Any help directions to where/ what to read or do would help. Thank you . Mike
Old Aug 3, 2013 | 11:46 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Reset your PCM and see if that helps your mileage. Other things like fuel quality, letting sit and idle with AC running, bad air filter, low tire pressure, ect all affect mpg
As for a flat spot, first thing that comes to my mind are the filters in the trans and the o-ring seal on the flat filter which sometimes causes an issue
Old Aug 4, 2013 | 09:00 AM
PRF66's Avatar
PRF66
Color me slow.........."the flat filter" You mean the air intake filter? Those clips holding the cover? Or..........The trans has a flat filter? Thank you. Appreciate your commitment to the boards. Regards< Mike
Old Aug 4, 2013 | 09:38 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
There are two filters in the trans. One is exactly like the spin on oil filter your engine uses
The other is a flat pancake style filter with maybe a 1" pipe or hollow plastic tube. The filter itself is bolted in place but the tube part slips though a seal.
Do a search here on the site or check our FAQs to see how to change transmission oil for pics
Old Aug 4, 2013 | 11:02 AM
p38251's Avatar
p38251
If you just had this done I would take it back. Even though its PM, there is still a warranty.
Old Aug 5, 2013 | 10:24 AM
Izero's Avatar
Izero
Take it right back to the dealer and tell them something isn't right.
They should definitely make it right for you ASAP.
