Windows
Old Aug 12, 2013 | 08:12 PM
brad m's Avatar
brad m
Default Windows
My driver power window auto down did something weird the other day. I tryed to put the window up but it auto down, and now it will not auto down. Is there a way to reset the window.
Thanks for the help.
Old Aug 13, 2013 | 12:13 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You need to take apart the switch and bend the contacts back or get a new switch. This is a common issue over time with usage
Old Aug 13, 2013 | 10:21 AM
Izero's Avatar
Izero
This is also a common issue if the switch got very wet (from rain or a drink spilled or something).
Old Aug 13, 2013 | 06:11 PM
MikeHTally's Avatar
MikeHTally
Not likely. The switches are well-protected from such calamities.
OP - what year?
Old Aug 13, 2013 | 07:32 PM
brad m's Avatar
brad m
Its a 2004. I took the switch apart and evrything looks fine. There is no way to re-learn the motor. Thanks for all the help.
Old Aug 13, 2013 | 07:52 PM
MikeHTally's Avatar
MikeHTally
My 300C sometimes "forgets" how its windows are supposed to work. To remind it, I hold the switch up (or down, depending on which motion it forgot) until the window "twitches". Your truck may have the same aggravation. The motor doesn't "learn" anything - it responds to the polarity of the signal.
