05 Ram wiring harness help
Hi everyone I have an 05 Ram 2500,4x4 hemi. I have a no start no cluster issue. I have pulled the fuse box and I have corrosion in a couple of the terminals of the main harness. Particularly the ignition one. One of the wires actually came right out, the black plastic dust/dirt cover had slipped off and was more open to the elements than usual.
I want to clean all of the terminals as best as I can on the harness plugs and on the fuse box/ipm. Do I coat all contacts with dialectric grease after cleaning?
Do I need a special crimper terminal removal tool for these plugs? Where am I able to buy these terminals? I also have a broken lock tab(the grey hinged one on a separate plug)Should I replace the entire plug end and are these only available from Dodge?
I just want to inhibit further corrosion as these aren't weather proofed to withstand Alberta winters. Not sure they are weather proofed to withstand much to be honest.
