4.7L "copper core" spark plugs?
Old Oct 3, 2005 | 06:00 PM
mleeser's Avatar
mleeser
Default 4.7L "copper core" spark plugs?
I have an '03 ram 1500 with a 4.7L engine. I noticed this in the service manual.
CAUTION: The 4.7L V–8 engine is equipped with
copper core ground electrode spark plugs. They
must be replaced with the same type/number spark
plug as the original. If another spark plug is substituted,
pre-ignition will result.
I need to buy a set. What are you guys using for plugs? Does anyone know what they install at the factory? I guess I could go pull one and look at it but that would be too easy...
Old Oct 3, 2005 | 06:51 PM
mleeser's Avatar
mleeser
Default RE: 4.7L "copper core" spark plugs?
I found the factory plugs listed in the engine compartment. Champion RC12MCC4. Still curious to know what others are using.
Old Oct 5, 2005 | 01:14 AM
mill500's Avatar
mill500
Do a search on here....I did awhile back and everybody's all over the road on what they like, but it seems to be a consensus that nobody thinks they multi-tips are worth the money.
I'm ready for my 30k maint (Hemi) and will probably just stay with the Champs. From what I've seen, the Platinums will last longer than the copper. The 04 doesn't have that disclaimer that I've found that specify copper. The way I look at it, it doesn't run bad on the stock plugs.
Old Oct 5, 2005 | 01:31 AM
osteodoc08's Avatar
osteodoc08
Copper does erode faster than some of the precious metal tipped and cored plugs. Like you said the truck runs fine on the copper ones. In the end, I guess I will stick with the stock plug, because once you add up the cost of 8 or 16 in my case, it gets expensive fast. That is before all of the other recommended maintenance at 30K miles.
Old Oct 5, 2005 | 02:16 AM
DonG's Avatar
DonG
I always run champions in my 4.7 dakota and just put replaced them in the 4.7 in my jeep. The only problem with them is that they only last about 25K. If you haven't changed them in that many miles you will see the gap is about twice what it should be and notice a performance improvement.
