power steering
Old Oct 29, 2013 | 01:17 PM
huffjacob92's Avatar
huffjacob92
Default power steering
I Have A 2003 Dodge Ram 1500 AnD This Morning i Realized My Power Steering Fluid Was Almost Dry So I Went And Put Some IN It. It Drove Perfect All Day, Then At Night When It Got Colder It Wouldn't Turn In Park And Very Hard To Steer At Low Speeds. IT Drove Just Find At Normal Speeds. I'm Not Sure If Air Got In The Lines Or what. There Are No Leaks That I Can See. What Do You Think Is Wrong?
Old Oct 29, 2013 | 06:08 PM
abarmby's Avatar
abarmby
Check to see if your ps lines aren't leaking.
Common problem on cheap hose clamps Dodge used. Also check to see if your power steering boots aren't filling up with ps fluid.
That's common as well and is usually the seals on the ps rack leaking.
Al.
