2004 Ram-Door Ajar Stuck On
Old Nov 12, 2013 | 06:27 PM
dtimberwolf's Avatar
dtimberwolf
Default 2004 Ram-Door Ajar Stuck On
My door ajar alarm just started coming on continually when excellerating beyond 15 to 20 miles an hour. All doors are in fact latched. I sprayed WD40 on all 4 Quad cab door latche's, but with no resolve.
What is the proper step to take to correct? 75% of the time its strictly drivers door that gets the use, so I would think this is suspect. The rear left passenger electrical lock hasn't responded in approx. 1 year.
Thanks
Old Nov 12, 2013 | 08:43 PM
scwpd's Avatar
scwpd
Check the wires that run in to the doors very common problem for them to break
Old Nov 13, 2013 | 02:23 PM
Izero's Avatar
Izero
there is also a door close sensor somewhere that may have failed... I had this happen on an SRT-4 I was putting a remote start in and it drove me nuts....
Old Nov 14, 2013 | 05:42 AM
dtimberwolf
Will do. Yesterday I determined the door causing is the left rear passanger, so I'll check its wiring.
Thanks!
Old Nov 14, 2013 | 12:32 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As said, if it's not in the wiring the the door latch assembly has failed. It is replaced as a unit. I think we have a How To in that section. It's simple to replace though
