Very satisfied with new mods...
Old Oct 7, 2005 | 02:45 AM
kingaling1986's Avatar
kingaling1986
Default Very satisfied with new mods...
This may also help those of you with the programmer dilemma. I have wreaked much havoc here in Geogia now that I have discovered the potential of my previously stock 4.7L truck. I finally got my stuff from RPM Outlet and got it put on as quickly as possible. The K&N CAI not only looked great, but added a LOT of growl under the hood. I was quite surprised. The throttle body spacer (which was pretty much a freebie considering the cost of the whole kit) whistles when I get on or off the pedal. After allowing my boyfriend who has a 2500 Hemi try the superchips max microtuner on his truck (he almost peed himself), we put his back to stock, and then programmed mine. The superchips programmer does allow for tire size change, but wont let you customize shift points. However, it DID change them on its own in the "performance" tuning setting. Overall, the truck shifts harder, sounds better, and is MUCH faster. Next will be dual exhaust. Can't wait.
Old Oct 7, 2005 | 02:54 AM
Bruce's Avatar
Bruce
Default RE: Very satisfied with new mods...
Gotta get a superchip,got to make a good excuse to get it by the missus[sm=kissykissy.gif]
Old Oct 7, 2005 | 03:09 AM
kingaling1986
I have been getting about 2 MPG better than before, but this is most likely due to the CAI. It still might work as an excuse though.
Old Oct 10, 2005 | 12:41 PM
jayskynr's Avatar
jayskynr
ORIGINAL: kingaling1986
You mean to tell us he was able to program his and yours with the same tuner?? I was told these things are vin locked : once installed on one truck it cannot be installed on another . I was wondering about that one .
Old Oct 11, 2005 | 01:55 AM
YeahItsAHemi345's Avatar
YeahItsAHemi345
You can install then uninstall...then you can install it on another car/truck. It will only work one at a time.
Old Oct 12, 2005 | 04:50 PM
kingaling1986
Yep, but I have also been told that you can make them program more than one at a time... if you are a gifted hacker and void the warranty by hooking up to the bottom of the programmer, which, I believe, is a USB port? Given the fact that it voids the superchips warranty, I would advise against it.
