supercharger
Old Oct 7, 2005 | 06:10 AM
njcoach's Avatar
njcoach
Default supercharger
does anyone have this.... thinking of getting it...
Dodge 5.7L Hemi Supercharger Kit
There has been so much hype and so many requests for Dodge Ram owners surrounding a “functional” blower kit for the 5.7 Liter Hemi powerplant. So GS Motorsports teamed up with Paxton Superchargers, as a result we are proud to announce the release of the Paxton supercharger kit now available for 2003-2005 Dodge Hemi Ram Trucks.
At the heart of the Hemi Ram supercharger kit is a Novi 1200 head unit, capable of 1000CFM and 680 horsepower, this is a new head unit from Paxton used in their Denali and Escalade kits (nothing but the best for you Hemi guys!) Along with a top of the line head unit this kit comes intercooled via an air to water aftercooler setup, just another plus to this Hemi kit. As with all blower kits you need additional fuel in some way shape or form, through much experimentation we found the auxiliary injector setup with a custom Hemi Fuel Controller to be the weapon of choice. All kits will come preprogrammed with a fuel curve for use on the Hemi 5.7 motors, all this in an effort to make the hemi Supercharger kit as plug and play as possible. The GSM/Paxton Hemi Supercharger Kit will carry a 1-year warranty on the Novi 1200 head unit and a 1-year warranty on the electronics components of the kits. All warranties will be valid from the ship date on all Hemi Supercharger Kits through GSM and Paxton.
System Contents
Novi 1200 Supercharger Compressor
Air-to-Water Aftercooler
Setrab heat exchanger
After-cooler water pump and all wiring
All 1/2" billet supercahrger mounting bracket, hardware, and belts
Aluminum discharge and intake tubes
Oil Feed and Oil Return Assembly
By-Pass Valve
Custom Hemi Fuel Controller Box pre tuned for stock Hemi
GSM Custom Hemi Fuel Controller
Billet auxiliary fuel rail and throttle body spacer
Stainless braided fuel lines with all fittings to attach to stock fuel rails
2 Auxiliary fuel injectors
Custom Hemi Spark plugs made for S/C application
Full instructions for blower and fuel system install
Up to 400rwhp on 6psi Kit
Up to 500rwhp on 8-10psi upgrade kit (Dyno tuning is required, for boost upgrade kit.)
Warranty:
1 year warranty on quality and craftsmanship for the blower head unit & electronics
Optional Upgrades:
Part Number: (GS-HEMI-1UP) Complete 8-10psig Big Boost Upgrade Kit - $489.00 (Dyno tuning is required, for boost upgrade kit.)
Old Oct 7, 2005 | 01:11 PM
Joey0480's Avatar
Joey0480
Default RE: supercharger
dude, you get that, I have to see it!
