Oil Pressure Needle Slow At Startup
Old Dec 17, 2013 | 07:16 PM
CodeBlox's Avatar
CodeBlox
Default Oil Pressure Needle Slow At Startup
When I first started driving this truck around 15,000 miles, the needle for oil pressure used to jump up really fast. I noticed that now (at 60000 miles) the needle doesn't jump up quickly to where it'd stay. It does go to the normal level but it does so at a slower speed. Is this normal or could there be an issue now? Perhaps I am just being paranoid about the whole thing.
Old Dec 17, 2013 | 09:07 PM
TRO14's Avatar
TRO14
Get a mechanical gauge and check to see what your true oil pressure is. The stock gauge is a dummy gauge. It reads normal as long as the pressure is in between a predetermined range. It doesn't show the true pressure.
Old Dec 17, 2013 | 10:10 PM
dirtballer's Avatar
dirtballer
Will it drop if you are running low on oil?
Old Dec 17, 2013 | 10:13 PM
TRO14's Avatar
TRO14
Only if the pressure drops below the specified "safe" range.
Old Dec 17, 2013 | 10:31 PM
CodeBlox's Avatar
CodeBlox
Hmm, lets say I get a gauge and get a pressure reading... What would be considered a "normal" reading for a 2007 2500 HEMI?
Old Dec 17, 2013 | 10:57 PM
dirtballer's Avatar
dirtballer
How do I find what the safe range is (presure)
Old Dec 18, 2013 | 08:09 AM
TRO14's Avatar
TRO14
I know mine typically idles fully warmed up with around 50 psi.
