2003 Ram hemi "oil pressure issue"
I have a 2003 5.7 hemi. 104k. Has been running well. On way home from work at start up I noticed the check gauges light, and the oil pressure gauge at 0. Engine sounded slightly higher in tone I suppose. I got home, and checked oil, a bit dirty looking but level was fine. I turned on and off a few times and suddenly the gauge light went out and pressure returned. I noticed the idle smooth out a bit at that point. I drove it to get gas and seems ok, no knocks or anything. What could have caused that? I'm in
Minnesota, and it's been very cold lately, could that be a factor?
Greetings from South Dakota! I will move you to the right spot.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
First thing to do without fear of wasting your time and money.... Do an oil change. It's possible your filter is clogged. After all, you did say your fluid is dirty so it needs to be changed anyways.
(I should've ran some Seafoam thru it before the oil change though.)
