2007 1500 4x4 Clunk
I've had a clunking noise coming mainly from the right front/middle of the truck ONLY when I disengage the 4x4. There's no worrisome noises while in 2x4 nor when I'm in 4 wheel, but when I turn the *** from 4 locked to 2 wheel there's a very noticeable "clunk" around 10-15 seconds after turning the **** to 2x4. It's more obvious when at speeds around 20 to 40mph and you can feel it as well around 40. I haven't tried it at any higher speeds for fear the truck would self-destruct. Before I head out in the Arctic air and take a look, are there any suggestions as to what it may be? This just started within the past few weeks.
OP, are you engaging/disengaging while on dry ground? dry ground will cause noises because there's no tire slip involved.
Also, it's 4x2, not a piece of wood(2x4) ;-)
He's disengaging the front diff. He never mentions anything about mileage or his maintenance schedule. So, what part of that info makes you think his diff fluid is due for service?
The clunk is probably within the transfercase, Not the diff.
You don't need to throw your truck in neutral and I actually wouldn't recommend such advice.
I've shifted my 2008 into and out of 4wd at 65mph and it was so smooth you couldn't even tell. i did it with even gas pressure and while coasting and it made no difference. The reason it makes no difference is because when you are coasting, the pressure is on the backside of the gears at the same pressure as when you are cruising and the pressure is on the front side(leading edge) of the gears.
What I wouldn't recommend is to engage 4wd while hammering the gas or while turning!
Thank you all for your help
I usually never have it engaged while on dry ground and lately the roads have been mostly snow/ice covered. Thanks for the correction, I had a good laugh about it
The truck has about 45,000+ on it so it is worth looking into. Worth noting that I took a quick peek last night and noticed a bit of fluid build up around where the right front axle meets the differential. Perhaps it's just a seal that is shot??
Agreed!!
Make sure you check out the Maintenance FAQ I posted for all fluid types and levels etc.
I combined all info, but it's handy and in one spot.
https://dodgeforum.com/forum/3rd-gen...nce-specs.html
